"clutch lining on Irvine 36 engine"
Hows it goin guys, I've a concept 30 srt with an irvine .36 engine. I've had it flying a couple of times, with the inevitable happening (a crash !!). Had to replace most of the tail rotor section, tail boom, main blades,clutch, etc, etc.
When replaceing the cluth liner should the clutch be totally free to rotate inside the drive gear or should there be contact with the clutch liner. If there should be contact how much friction do I need against it for the engine to turn over.Also how does the clutch disengage for the blades to turn. Any help would be great.
Cheers !!
Cheers !!
RE: "clutch lining on Irvine 36 engine"
