Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 First flight Gyro problems??? >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 11-01-2003 | 09:50 AM
Default First flight Gyro problems???
Test new Raptor60 with the 410 gyro. The nose wants to swing left fast. Our senior member and myself have spent a couple of hours just reversing the everything. Weve tried every combination with the same results every time hard nose swing to the left. Would anyone have the full settings for the JRx-378 Radio?? any help would be apprectiated..
Old 11-01-2003 | 01:07 PM
Default RE: First flight Gyro problems???
Try www.raptortechnique.com
He has a really good setup procedure for the 401gyro with a bunch of different radios.
Also shows ways to test the setup to be sure everything is moving in the right direction. Hope this helps. Dave
Old 11-19-2003 | 03:12 PM
HenRam's Avatar
I've seen a few of the 401's not functioning out of the box... Make sure the gyro is working... Move the tail rapidly and see if the rudder servo compensates. Check your setup, when you move the rudder stick to the left, the slider should move to the right, when looking at the heli from tail to the nose... Once you have that straightened out... move the heli's tail to the left, a right input should be seen at the servo to compensate for the unwanted movement. If all this is tested on the ground, it should work in the air.
I'd also remove all delay from the gyro, make it 0. Make sure the sensetivity is up there, if you have it too low, it might not want to hold. Some people I know need to start the heli, while the TX is in HH mode. Then swtich back to normal mode and start the heli up. Don't know if you're radio is setup this way too... The light should be off in normal mode and on during HH, if it's blinking, it wasn't initialized correctly....
Let me know if any one of the suggestions helped
