RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
tail control
Old 11-10-2003 | 05:37 PM
Default tail control
I have been fllying a quick 50 with an os50 engine for about a year now. my heli was set up fine, but now all of a sudden when I take off straight up with power the heli twist to the nose left pretty forcfull. I use the futaba 401/9253 gyro and previously when I pulled straight up with power the tail staid perfect right where it started. I can't figure out whats making the tail twist in avc mode. help
Old 11-10-2003 | 06:29 PM
Default RE: tail control
There could be a problem with the servo. Just a guess.
Old 11-10-2003 | 09:43 PM
EC120's Avatar
Belt driven tail. Tighten it up a little. They can loosen over time. Also check pulleys and belt for damage.
Old 11-19-2003 | 02:48 PM
HenRam's Avatar
Had a similar problem... Had a hard time trimming it out and wagged quite a bit... Also would turn when applying full + or negative.... Tried tweaking the gyro settings for about 2 weeks before I noticed the belt was loose... Luckily never lost the heli due to the fact. Check the belt
