pico mini heli?
pico mini heli?
Hey all u heli enthusiasts...
Does anyone know anything about the pico electric heli? I am an avid electric lover and have always been interested in this mini heli...though I have not ventured into the heli world just yet. It can be seen at ----->
http://www.horizonhobby.com/products...50&pc=IKA67350
Does anyone have one of these or heard anything about them...or for that matter any other elctric heli on the market?
thanks
crf
thanks
crf
pico mini heli?
go to http://microhelis.homestead.com/index.html for more info. The tail response on the Piccolo is not as good as the Hornet, but the Piccolo is lighter and gets better duration. The Hornet has higher headspead and thus tends to be more stable outside in a breeze. Both helis can be upgraded to collective pitch versions which fly much better and are more stable and controllable. Neither is a good first heli though as their small size makes them tough to fly. The same manufacturer that makes the Piccolo also makes the Eco 8. Also, the Lite Machines Corona is a bigger electric heli. Both would be great first helis if you are an electric fan.
pico mini heli?
uicfletch wrote on 05-14-2002 9:18 AM:
Thanks for the info
Another question....if someone asked you how hard it is to hover a heli, what would your response be? Is it something that will take quite a long time to master, or can you get going on the right track as long as you have the training gear? Also, what are the control surfaces for these helis....simply put - how do they hover?
thankx
crf
Thanks for the info
thankx
crf
Hope this helps. I posted it because it seems to me that his is a question of general interest.
IL
electric
With the Corona 120 you could use a aircraft radio. Looks like you have been in to planes so you have a radio. Right?
The Corona 120 is Easy to build. ( Easy to set up because it is a fixed pitch) Very forgiving Crashes are little to no damage $0 to $20 witch makes up for the fixed pitch. (rise and drops in high wind)
