Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 'Normal' vs CCPM vs eCCPM >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 12-29-2003 | 01:44 PM
markfsanderson's Avatar
Default 'Normal' vs CCPM vs eCCPM
I'm relatively new at all of this, and have question . . . Why do the 'performance' helicopters seem to come with ccpm/eccpm control but the 'lower' end tend to come with the 'regular' style? My raptor 50 v2 uses the 'normal' type (according to my JR 378, that is) but the JR Helis that I've seen seem to prefer the CCPM . . . .
thanks!
Mark F. Sanderson
Old 12-29-2003 | 02:03 PM
bdphil's Avatar
My Feedback: (26)
Default RE: 'Normal' vs CCPM vs eCCPM
CCPM/eCCPM/EMS = same thing
Mechanical mixing or electronic mixing are just 2 different ways of accomplishing the same thing. There are advantages and disadvantages to both. Whether a helicopter is a 'performance' helicopter or not has little to do with whether it uses CCPM or mechanical mixing.
Ben
Old 12-29-2003 | 02:31 PM
Ben,
What might be those dis/advantages?
Thanks!
Mark
Old 12-29-2003 | 02:49 PM
bdphil's Avatar
My Feedback: (26)
Advantages of CCPM: Fewer parts, less complicated to assemble and repair, distibutes the forces over several servos.
Disadvantages of CCPM: Almost demands very precise servos, very sensetive to proper setup or you end up with interaction between functions (even with proper setup you can have a small amount of interaction).
Advantage of mechanical mixing: Less confusing radio programming, no interaction between controls
Disadvantage of MM: More parts, not much else - mechanical mixing works just fine
Ben
Old 12-29-2003 | 02:55 PM
What do you mean by 'interaction'? Does this mean that operating collective could 'accidently' mix in some cyclic in the wrong direction if not perfectly setup - or something to that effect?
Mark F. Sanderson
Old 12-29-2003 | 03:51 PM
bdphil's Avatar
My Feedback: (26)
Yes. Since you have 3 or more servos all controlling the swashplate at the same time if they don't travel at the same speed and/or have exactly the same endpoints - you will get an interaction.
Most new CCPM helis have been designed to reduce this situation, but it still requires careful setup of the servo arms, pushrods, and bellcranks. Using precise servos, like digitals, will also make it easier to set up. Most computer radios have some features to help with this too.
Ben
Old 12-31-2003 | 09:02 AM
Go to our club site for some details on mixing types and pros/cons.
www.scotiabladerunners.ca
Go technical, then theory of flight.
