RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Overpitching?
Old 01-07-2004 | 06:40 AM
Default Overpitching?
At full power/collective the rotor RPM of my Ergo sounds like it is reducing slightly.
How do I tell if it is my engine that needs tweaking, or if the blades are set up with too much top end pitch?
Old 01-07-2004 | 05:18 PM
Charlie's Avatar
Default RE: Overpitching?
What size is your Ergo and what is in it for a motor?
Old 01-07-2004 | 05:42 PM
Model is an Ergo 30 with OS32 power.
Old 01-07-2004 | 06:18 PM
Charlie's Avatar
Make sure you don't have anymore then a +9 degrees pitch, if that is to much ( it shouldn't be) then drop it back to +8, don't go any lower the that. If that doesn't work then try to lean it out a couple of clicks on the needle. The OS32 should be able to pull a +9. All you can do is play with it and see what happens. It could be in your pitch/throttle courves, you mite have to play with them to. It's hard to tell without seeing it. You mite won't to find someone that knows about heli's to have a look at it for you.
Old 01-07-2004 | 06:41 PM
Thanks for that. I think I'm running about +10 pitch and it only bogs down a little. I'll drop the pitch down and I think that will do the trick!
Old 01-07-2004 | 09:16 PM
My Feedback: (30)
Get a MA optical tach. It is the best tool ever. Then you will see what the correct top end pitch should be without guessing.
Old 01-08-2004 | 03:32 AM
Charlie's Avatar
I think he means MA pitch gauge?
