RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
CCPM what is that???
Old 03-18-2004 | 04:27 PM
My Feedback: (21)
Default CCPM what is that???
Please help me to understand what exactly CCPM is for. Is better for sport flying and 3D? What are advantages and disadvantages?? I am using Futaba 9 CAP; can I fly heli w/ CCPM??? I am asking all this because I want to get the JR VEnture 50 w/ OS 50 engine. Is it good heli to lern 3D or should I be looking for something else?Thank you in advance.
Old 03-18-2004 | 05:25 PM
Default RE: CCPM what is that???
http://www.rotory.com/ubbthreads/sho...b=5&o=&fpart=1 check out this thread.......
Colin
Old 03-19-2004 | 03:56 AM
RotorNut's Avatar
First off yes the 9cap will do CCPM. CCPM stands for collective cyclic pitch mix. In CCPM 3 servos work together to move the swash plate. Where a standard system 3 servos work independently to move the swash plate. In CCPM when you give collective input all 3 servos move together to increase and decrease collective pitch this gives you 3x the servo torque on moving the collective. When you give cyclic input 2 servos move together. I have flown both types and I definitely prefer the CCPM the controls are a lot smoother. the biggest advantage of CCPM is that you don't have to use as high of torque servo on the swash so it saves some money on servo cost and power consumption is less.
Old 03-19-2004 | 11:43 AM
you can do CCPM mechanically or electronically. Rotornuts example is of an eCCPM control system, something like a raptor is mCCPM.
Colin
Old 03-19-2004 | 12:28 PM
fellers's Avatar
I just recently got a CCPM heli my self after years of flying mechanical mix and i must say the CCPM does seem smoother alot smoother when you have your pitch and throttle curves right to. Just use a swash leveling tool to make sure your swash is going up and down level from low to high stick on your throttle.
Don't know much about the Venture .50 but from i have read it sounds like a decent heli that will 3D and FAI maneuvers.
FAI is precision flying like exiting a maneuver in the same spot you entered it where 3D is basically controlled falling with random extreme maneuvers are done at the pilots wish. Not so much precision flying as FAI though you must precise at all times anyways
Check out the Hirobo Sceadu Evolution .50. Critics are comparing it's power to weight ratios of the .90 size helis. Sounds like it could be a heck of a 3D machine. Also a clip of it flying on the IRCHA 2003 video i believe.
Old 03-19-2004 | 02:15 PM
The mCCPM has come a long way, the Evo is mCCPM or as some call is mechanical mix....the mCCPM now a days is great
Colin
Old 03-19-2004 | 02:34 PM
fellers's Avatar
Amen to that statement
ORIGINAL: raptor_dude
Colin
Old 03-19-2004 | 11:43 PM
will the Airtronics RD6000 sport support CCPM?
Old 03-20-2004 | 12:10 AM
fellers's Avatar
I do beleive that that radio will operate a ccpm heli
Old 03-25-2004 | 02:02 AM
marked23's Avatar
There is more than one eCCPM. When the ad says CCPM it usually means 120deg CCPM which is three servos moving a swash plate with balls at 120deg. An equilateral triangle. The latest thing in CCPM is the 140deg design. It places all the ball joints an equal distance from the main shaft in in a fore-aft perspective. The proposed benefit of 140 is that for elevator changes the servo response speed is equal between the front servo and the the rear servos. It's something only FAI flyers would appreciate. Apparently, with 120 there is a slight change in collective when making a sharp change in elevator. 140 is only supported on high-end radios.
Also, according to my radio, there are 90deg and 180deg CCPM modes too. I don't know anything about those.
-Mark
Old 03-30-2004 | 06:14 AM
My Feedback: (41)
Will a new JR 6102 support eCCPM? Is a Venture 30 a CCPM system and did they ever have just a Venture 30 CP only and is the CP model obsolete? Thanks, Mike
Old 03-30-2004 | 09:06 AM
fellers's Avatar
My buddy judt bought a 6102 for a Venture .50 which is ccpm as well as the venture .30 CP. It is a fairly new helicopter. That radio will be great for a venture ccpm heli. It even has graphs for pitch and throttle curves. Decent radio!
Old 03-30-2004 | 01:57 PM
My Feedback: (41)
Great news. I wonder why Horizon sells the 6102 as an Air and Heli version? I have the Air version one and it's got Heli programming in it. I'm lucky that it works for the CCPM. I also have a JR10X but that's a dedicated Airplane radio. Thanks again, Mike
