TJP Help please
TJP Help please
I’ve just installed a throttle jockey pro in my sceadu (radio field force 9)
Last week it was working great, the only thing is, up until last week I had not flown the Heli’ for 4 months and it was running rich on the bottom end,
So I leaned out the bottom end a touch and that raised the idle RPM so therefore my throttle cut would not work,
so I then lengthened the throttle linkage to lower the RPM so my throttle cut switch would work and altered the end point to suit.
The ‘top’ end point has gone up to 124% this has raised the governor rate values too
‘Normal mode which is disabled at 75%’
And idle up 1 (head speed 1800rpm) was set at ‘78%’ has now risen to ‘97%’ is this ok?
Or do I need to install a larger servo horn on my throttle to lower the end points near 100%
Any help much appreciated
RE: TJP Help please
Did you reprogram the TJ? After making any drastic changes in endpts, linkages, or curves, you need to start over on the programing steps of the TJ as you have altered the parameters on which it's data is based.
Elmo Te
Elmo Te
RE: TJP Help please
Elmo Te
Thanks for the reply
the instructions say set the throttle end points to as close to 100% as poss
but I think I need a longer servo horn to get more movement that will bring the endpoint down
and also the gov rates hopefully
ps I did recalibrate
Geoff
Geoff
