Vibration
Hi.
Is there any easy way to eliminate paddle bar vibrations?[:-]
what i have in mind is spooling the rotor system up without the main blades on...
Anyone attempted this?
First: If you have a vibration coming from your fly-bar, something is not setup right. Go over everything and make sure it's right.
Second: You can spool your heli up with out the blades on, just don't go to high. Only open the throttle about 1/4, don't go any higher or you start over speeding the motor
