Raptor 30
Question!
Is it normal procedure after prolonged brake in to set the high end needle to manufacturers instructions and then control the temperature with the low end needle? The only way I can get my high end needle on my TT39 to be within the recommended range is to set the idle mixture to excessively rich in order to keep under ideal temperatures. Any comments?
One other question? What's the most I can expect out of a stock Raptor 30 v2 with a TT39 in the 3D department. Is it capable of extreme aerobatics without bogging down or is not able to handle a full load???
Set your low needle so you get a good idle, then you set your high needle to get the temperature you won't. With heli's you are alway's flying on the high needle not the low. Your low needle is just to get you in the air, after you are in a hover you are on the high needle.
<blockquote>Quote
<hr>What's the most I can expect out of a stock Raptor 30 v2 with a TT39 in the 3D department. Is it capable of extreme aerobatics without bogging down or is not able to handle a full load??? <hr></blockquote>
Your TT39 should do any 3D stuff you won't to do, if it is bogging down something is not set right (throttle or pitch curves). What are you running for pitch? You don't want anymore then a +9 on the top and about a -8 on the bottom. You don't need as much pitch for inverted flying. These are just ruff numbers you will have to do your fine tuning at the field( but I haven't seen or heard of a 30 size heli pulling anymore then a +9) if you have more then a +9 it will bog.
<blockquote>Quote
