Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Need Howto help on flips & rolls >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 07-29-2002 | 04:48 PM
jctpro's Avatar
Default Need Howto help on flips & rolls
I am flying around fine and can manage loops fairly well and would like to start doing more. I am not sure what the correct inputs are for good flips and rolls. Is a flip the same as a loop but with no forward flight to start things off?
When I try a roll it has a barrel shape and not an axial roll.
I am flying a .30 Raptor.
Old 07-29-2002 | 04:52 PM
Furyflyer2's Avatar
My Feedback: (117)
Try to perfect a axle roll and a loop before you go into flips. Flips require the right amount of cyclic and pitch changes.
"Is a flip the same as a loop but with no forward flight to start things off? "
Basically yes, but require the right input.
Old 07-29-2002 | 05:02 PM
Collective pitch timing is the secret to doing nice axial rolls. When the heli blade disk is perpendicular to the ground you should be at 0 pitch. When inverted you should have a little negative pitch. Then back through 0 again when perpendicular before coming upright.
I practice by doing stationary rolls and when I do them while staying in the same place in the air the timing is right.
Try moving the collective slower through the range when doing a roll. I see a lot of new guys that are moving the stick too fast and end up with a barrel roll.
