RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
remote glow clip
Old 10-10-2004 | 04:39 PM
Default remote glow clip
does anybodt make one of these that lasts longer than a month?! my 4th one has just died and its doin my head in, the wire either fatigues and breaks at the engine side or the glow side. ive tried fixing all of them but the fix never lasts long so i end up getting a new one. i know there only cheap to buy but surely should last longer than this?
Old 10-10-2004 | 04:57 PM
Sabot's Avatar
Default RE: remote glow clip
i have a thingy which connects my power panel to the glow plug, i dont know if its the thing your talking about but mine has never failed me
-Sabot-
Old 10-11-2004 | 11:53 AM
yeah you connect your glowstarter to the glow clip, the glow clip has a wire that goes to the engine and a wire that goes to the glow plug.
Old 10-11-2004 | 07:15 PM
lawnhawk's Avatar
Dan,
Try the one from MPI. I had a Sullivan, which was junk, but I've had the MPI one on all season.
http://www.maxxprod.com/mpi/mpi-22.html
Regard,
Rich
Old 10-11-2004 | 10:57 PM
I've got so frustrated with the poor quality/longevity of all of these remote glows that after much trial and error, I've found that the best setup is to replace the engine end plug with an insulated croc-clip. Works every time, never falls off, easy to get on and off, much better than either the bent wire type or the cap type of connector
Old 10-11-2004 | 11:41 PM
The best one I have tried is made by O.S., it is called Booster Terminal Kit , I have ben using it for at least three years in a scale model heli with out any problems
Old 10-12-2004 | 02:11 PM
yeah it tried the croc clip fix but then it broke at the other end lol im sure ill find a good un eventually. least i know its not just me anyway.
Old 10-13-2004 | 07:39 AM
BarracudaHockey's Avatar
Heliproz sells one for the Raptor made by Maverikk that has held up pretty well on my 50 and I just put one on my nexus scale ship.
http://www.heliproz.com
Old 10-13-2004 | 10:51 AM
My Feedback: (15)
Alligator clip from RadioShack etc. here and it lasts plenty long.
Old 10-13-2004 | 02:22 PM
Over the years I have tried the McDanials one,TT one, the KSJ one, the Century one and a few others. They all fail sooner or later. But by far, the longest lasting ones have been the ones from Century.
Old 10-14-2004 | 09:59 AM
heli-john's Avatar
I use an RCA socket (female - get it from Maplins for pence) mounted to frame and connected to glow plug with wire(coiled) to a croc clip permanently attached to the g plug and an earth runs to engine bolt. Then have the male plug on the end of a lead to my power panel in my field box. The lead is about 3 feet long. Never ever have any problems and is soooo quick. Only ever used my glow plug gizmo once and hated it.
Old 10-15-2004 | 11:05 AM
now that sounds like the best idea ive heard so far i think ill give that a go. cheers
Old 10-16-2004 | 01:29 PM
Hanger 9 make one similar to that. instead of a "dummy glowplug" for a connecter it has an 1/8 inch? jack. i looks like a headphones jack. it also comes with a wire with the male jack on one end and a connecter that you attach your glow igniter to. i just leave the wire adapter attached to my igniter and just slide the jack in or out on the heli. hard to explain. but is exactly the same as the one described by heli-john exept is uses a headphone lack instead of RCA jacks, and its not home made. have yet to have any trouble with it.
here it is....
[link=http://horizon.hobbyshopnow.com/products/description.asp?prod=HAN3025]Hangeer 9 remote glow clip[/link]
Old 04-27-2007 | 01:31 PM
I am having trouble getting the glow driver to connect the the remote glow plug. It will not lock in. any ideas?
Tom
Old 04-27-2007 | 01:51 PM
Kevinator9's Avatar
What kind of glow stick?It may be one that you need to push it in, then twist it and it will lock on, or you may need to pull back a metal ring, push it against the plug and then let the ring go and it will lock in, those are the tqo glow sticks I know of...
