RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
winter questions
Old 01-11-2005 | 09:52 PM
Default winter questions
Is it bad to keep gas in the tank while my rc stuff is stored for the winter?
Thanks.
Old 01-11-2005 | 10:07 PM
Default RE: winter questions
YES! Remove your fuel from the tank and make sure all the fuel is out of the engine. I use After Run Oil in my Nitro cars when I put them away.
Old 01-12-2005 | 11:30 PM
okw
You can leave fuel in the tank as long as you keep it sealed; loop the fuel line from the vent line to the clunk line. As mentioned, you definitely want to clear the engine of all fuel and put after-run in it to keep it from gumming up.
Keith
Old 01-13-2005 | 02:52 PM
Remove all fuel from your tank, and use an after run oil on your engine for sure. With my planes, the nitro will cause the fuel lines to go bad -they will need to be replaced if ignored -including the clunk line. With higher nitro contents, it is worse.
Old 01-13-2005 | 06:43 PM
FLYBOY's Avatar
Never had that problem, but it will evaporate the nitro out and it will be flat. Better to suck the fuel out of the tank.
I also use Marvel oil in my engines when I store them. I use just reg mystery oil, I hear the tool oil works better.
Old 01-13-2005 | 07:41 PM
heli-john's Avatar
So you guys don't fly in winter then? I'm hoping tomorrow will see me out there.
Old 01-13-2005 | 07:58 PM
okw
I've never had a problem with the fuel lines either. I loop back the fuel line to seal the tank to keep moisture out (alcohol loves to suck up moisture!) and to eliminate the evaporation.
heli-john: I should have brought a heli to work with me today; it was 72 degrees and sunny! Of course there was that 25mph wind thing.
Keith
