Setting blade pitch help
FL
Can anyone recomend what blade pitch to use for a beginner. Shoule I use about 2 degrees negative and the rest positive? I am trying to set up a Logo 20 with 600mm blades.
RE: Setting blade pitch help
usual pitch is -2 to +9. -2 is needed to keep heli firm on ground when it is windy. +9 is plenty for most helis (but I'm not sure about electric, +9 could be too much or too little also depending on type of blades, rotor speed etc.)
Don`t put any negative on beginning,maybe 0- +7 degrees is good,when You can hover quite well put -2 to +9 so You can get Your heli down in windy weather.
WI
I agree. For a beginner just learning to hove, no negative. Use a curve of 0 (or +1) to +7 degrees. Otherwise when you drop the collective if you panic (WHEN you panic) you'll hammer the model into the ground. Likewise, too much positvice at the top causes the heli to zoom if you get over zealous. As you gain experience gradually move the curves toward the -3 to +9 or so.
Mike
Mike
I agree Mike. That is exactly the reason why not negative in beginning.You explain it better than I can
I know it because I chrashed maybe 5 times in beginning before I noticed it
WI
Me too. I also had to learn the hard way, self taught. I really wish there had been someone to help me at the time. I also recommend using the type of training gear that has the rods angled down slightly, not straight across. If I remember correctly the Heli-Max ones are like this. They have a wood block in the middle and the 4 CF rods plug in at an angle. It gives a little cushioning when the heli comes down hard.
You didn't mention wheher you had anyone to help you or not, If not, try and find someone to help you even if it means driving some distance to find an experienced pilot.
Good luck
Mike
Good luck
Mike
FL
Zero to start. I will use zero then. Does anybody know of a heli pilot in West Palm Beach FL that is willing to train?
Thanks for all of the advice.
ORIGINAL: jhbwaller
I'd go with neg 2 but dont slam the collective down in a panic. You go with 0 and it ballons on you in the wind you'll have problems.
WI
When I first started out I had my heli set up with +1 at the bottom, never had a problem. Besides which a beginner isn't going to be flying in much wind anyway. And the point is, you have to assume at some point you will slam the collective down. Telling yourself not to do it is irrelevant. It's a given.
My five pence - I'd suggest a little negative. If not -2 then -1. Why isn't there a "degrees" symbol on my keyboard?
A common recommendation with a few experienced heli guys is that +9' to -4' will give fairly good results, even into learning autorotation, WITHOUT having to set everything up and get used to it a second time...
