RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Cyclic limiter ring
Old 01-22-2005 | 01:11 PM
loadthis's Avatar
Default Cyclic limiter ring
Is a cyclic limiter ring needed on a ccpm heli? Where can I get one if I need it?
Old 01-22-2005 | 03:06 PM
flyerdarren's Avatar
Default RE: Cyclic limiter ring
not needed, you can just use some expo
Old 01-22-2005 | 09:19 PM
My Feedback: (9)
There was a guy on here that sold them but I can't remember his username. I used one for most of last season but it interfered with flying my planes so I took it off. I had to reduce total throws so there wouldn't be any binding "in the corners". Expo has nothing to do with what a cyclic limiter does.
A swashplate can only tilt so far. If you max out the tilt in both directions individually, when you command max in both directions it causes binding. There are many methods to set one up. Just try to get even amounts of throw in cyclic that is just short of binding when both aileron and elevator are at their max.
Matt
Old 01-23-2005 | 12:01 AM
okw
[link=http://www.ronlund.com]Rick's[/link] sells the cyclic rings. I've got one on my 9CHP and I haven't seen any problems flying my planes ... of course they haven't seen much air time recently. Every year, the plane:heli ratio gets smaller and smaller!
Keith
