RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
lubrication
Old 02-05-2005 | 10:22 AM
Default lubrication
How do you lubricate swash plate, bearings and the shaft? Is maverick mystery oil okay?
Thanks, in advance.
Old 02-05-2005 | 11:43 AM
BarracudaHockey's Avatar
Default RE: lubrication
I use Tri-Flo available from most bike shops.
Old 02-08-2005 | 03:53 PM
Yes swash gets union 76 as all other bearings. Bearings need THICK stuff, anything thin will be slung out and the bearing will then run dry.
On the shaft I also put union 76 now. I used to use teflon spray but that leaked down into the bearings, flushing them out and making a mess.
Old 02-13-2005 | 06:29 PM
Thank you all. I will try..
