Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 venture 30cp blade tracking >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 02-17-2005 | 07:00 PM
Default venture 30cp blade tracking
Hi again
I have run in to another problem once again. This time it involves tracking the blades. In specific what links do you adjust to make the blades track like there supposed to? The manual only tells you how to find if you have a blade tracking issue.
Old 02-17-2005 | 09:48 PM
Default RE: venture 30cp blade tracking
You can adjust the tracking from the double link going to the blade grips or the long links going to the mixing lever.
Look on www.raptortechnique.com he tells you how to do it.
Old 02-17-2005 | 10:06 PM
rlmarch I appreciate your help. thank you
Old 02-18-2005 | 11:01 AM
rusirius's Avatar
'zactly... In general, the short links right on the blade grips are a "course" adjustment, while the swashplate to mixing arm is a "fine" adjustment...
