RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Loss Of Power
Old 09-16-2002 | 03:42 AM
Default Loss Of Power
I have owned a Caliber 30 for a few months and have had about 30 good flights, until recently. The first flight of the day everything runs great with plenty of power, but after refueling for the second flight it has no power. It is harder to spool up, and barely gets off the ground. The first thing that i then do is lean out the engine, engine seems to run hotter when doing that but has tons of power. Again after landing and refueling for the third flight it has no power, can't even get it off the ground. I have replaced the glow plug from an os #3 to an os #8 and all of the fuel line. I am also using coolpower 15%. Any ideas anyone ???
Caliber 30
Futaba 9c
Gy 401
Os 32 sx
Old 09-16-2002 | 02:41 PM
Furyflyer2's Avatar
My Feedback: (117)
Makes no sense so it flys good one flight than changes the next? How old is the fuel? Are you using a fuel filter?
Old 09-16-2002 | 05:16 PM
I have the similar experience. The Caliber 30 was not able to take off after my third flight on the field last friday. I found out the tail rotor was somehow twisted 90 degrees. The servo was not able to move it at all. One of the set screw was also gone. I had to twist back the tail rotor 90 degrees back. I still have not figure out how the tail rotoer assembly was able to be twisted at the angle. I put another set screw in. Test flight, no problem. I think it might be the design error.
Good observation,
Chris
Old 09-16-2002 | 05:19 PM
I also replaced the original 1000mA Nicd receiver with 2000A NimH battery. I need to recharge after two flights. The NimH battery just last twice as long. I use JR550 gyro+JR 8700 super servo with CCPM setup. The extra capacity is just great.
Chris
Old 09-17-2002 | 01:55 AM
Have tried 2 different gallons of fuel, same results. Yes I do use a fuel filter and it is as clean as the day it was new.
Old 09-17-2002 | 02:02 AM
jnos, where do you fly at. I'm usually found at Grass Field on Hwy 169 north of the cities.
Ron
Old 09-17-2002 | 02:40 AM
I fly behind Vadnais Elementary School on a baseball field, never anybody there. It' s a few blocks from the corner of 35e and 694.
Old 09-17-2002 | 03:35 AM
did you check the clunkline inside the tank?
Old 09-17-2002 | 04:10 AM
Yes, I replaced that line also.
Old 09-17-2002 | 08:46 AM
If your out and about this weekend, stop by Sat after 4 pm or so, if your current AMA you can fly there as my guest. Its about 2mi north of co rd 81 on hwy 169, turn left at 101st ave, will see white shed, and if its a nice day, will see plenty of activity. They might be having races starting at noon, If you want to watch them stop by earlier, some of the planes are 200 mph.
Ron
Old 09-17-2002 | 08:49 AM
Also couple of good trouble shooters usually out there.
Ron
