RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Tail Wag
Old 07-22-2005 | 10:58 AM
Default Tail Wag
Hello Guys. I have an sceadu 50, o.s.50hyper and a GY401 with 9253servo. I use to fly my heli with 85mm tail blades. It seems they were to small and the gyro sensitivity has to operate at the limit. Change them for a pair of 97mm tail blades. Now at hover the heli seems to work fine but as soon as I start flying the tail starts wagging. I already lower the gyro sensitivity and check belt tension. I know some guys who are flying on a 92-97mm range without any problems. Some others say it is to much load for the tail. Wonder what else could that be
thanks
Old 07-22-2005 | 11:04 AM
BarracudaHockey's Avatar
Default RE: Tail Wag
Keep reducing the gain. Also check your ball on your rudder servo, should be about 14mm from the center of the spline.
Old 07-22-2005 | 03:59 PM
Well, the servo is 17.5 from the center.
Old 07-22-2005 | 04:46 PM
http://www.futaba-rc.com/team/team-tip-002.html
Your effectively increasing the gain and lowering the resolution of the servo at 17.5 mm
Old 07-25-2005 | 08:49 AM
ORIGINAL: barracudahockey
What do you mean by this? Am I doing something wrong??
Old 07-25-2005 | 08:55 AM
17.5 is a bit far. Around 14mm seems ideal.
You need to back off the gain, that is why your getting hunting or tail wag.
Old 07-25-2005 | 12:59 PM
thanks barracuda, I'll try that.
Carlos
Old 08-21-2005 | 09:06 AM
Hi Barracuda, you were right. It was the gyro gain. Thanks for your help. I really appreciate it.
Carlos
Old 08-21-2005 | 10:13 AM
Any time [8D]
