RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
blade size
Old 10-25-2002 | 03:08 AM
My Feedback: (-1)
Default blade size
i have an old concept 30that im getting back together but i need to know what size blades it takes. if anyone could help me with the main and tail blade size i would be most appriciative.
thank you marc
Old 10-25-2002 | 03:09 AM
Furyflyer2's Avatar
My Feedback: (117)
Default blade size
Main blades should be 550mm.
Old 10-25-2002 | 03:25 AM
My Feedback: (-1)
Default blade size
thank you fury
Old 10-25-2002 | 10:19 AM
Default blade size
It depends which C-30. I believe some of them used 515mm mainblades.
Vince D
Old 10-25-2002 | 11:57 AM
Furyflyer2's Avatar
My Feedback: (117)
Default blade size
Vince D
mrhook - Vance is right you may need 515 verse 550 contact Great Planes see what they say.
Old 10-25-2002 | 05:31 PM
Culverson's Avatar
My Feedback: (14)
Default blade size
If you have some available the Funkey blades are fairly good quality blades and reasonable as well. I paid $40 for a set for my wifes ZXX, I didn't even have to balance as they were dead on when I checked them.not bad for 40.00.
GL-HF
Old 10-25-2002 | 06:10 PM
Default blade size
If you find that you do need 550mm blades check out:
www.airborne-models.com
They have Fiberglass 550mm blades in semi and symmetrical for $28.00. I have been flying thier 600mm blades for a while and they are good bang for the buck, about the same price as woodies without worring about warpage and the plastic covering coming off. Thay have a carbon fiber reinforced leading edge with some wood spars inside, the aft portion of the blade is hollow. I have had the chance to check out what the insides look like on a couple sets of 600mm blades from them . Thay are white gelcoated also. They are not as rigid as the more expensive composite blades but they cost about 1/3-1/4 . The balance has been very close on mine as I use the koll to check all mine.
Vince D
