RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Eagle II Ex 98
Old 11-05-2002 | 01:33 AM
My Feedback: (9)
Default Eagle II Ex 98
HEY JEFF,
I had the great fortune to get the last EAGLE II EX 98 "special price" kit today, and was wondering if it can be uprated to the 99 or curent spec kit (condor I guess ?) .
I want to go to the nats next year, class II or III and want to have the best airframe possible .
I had nadier call you today and ask you about the top line blue fai head, and that got me thinking about what else there might be .
tell me what you think, regards, scott
Old 11-05-2002 | 02:37 PM
Default Hey dude
Actually, I would change just the head yoke to the WC 97 style. it is cheap and effective. The rest of the machine is fine. If you want the DTDS set, we have that in stock and you can add it to your heli pretty easily if you are planning on FAI. IF not fly it with the slipper assembly. Before you go changing it, fly it first and see how it works for you. Just because the heads are new, does not make them the best. What is best is what works for you. The rest of the airframe is still top notch and has a good history. Give me a shout if you want to talk about any other changes, but for the most part, build fly it and then see what you might want to do and then I can guide you better instead of just throwing dollars at it. That is unless you want to.
Nice to hear from you again Scott
Jeff
Old 09-28-2004 | 09:13 AM
Default RE: Eagle II Ex 98
Hi I have a eagle 98 EX, when I try to get it off the ground it want's to go on it's side, any info on this problem?
