heli fuel consumption
My Feedback: (21)
IL
I have a Century 50 and a new Raptor 60 that had its maiden flight the other day-MAN,this thing INHALES fule!!FAR more than the 50.
Im using cool power 30% for both..If I drop below 30%,can I expect to use even more fuel?how low can I go and still use the same fuel for both without the performance suffering?
Joe
Joe
RE: heli fuel consumption
I wouldn't go any lower then 15%, but that's just me. Your going to suffering a little when it comes to performance but unless your into heavy 3D flying you will never notice the difference.
Lets see now, .50 + 20% = .60
Would you say that you're seeing 20% greater fuel consumption? Because that would kind of make sense.
However, it will also have a lot to do with the gearing, motor RPM and head speed of each heli. If you've got a really peeky .60 setup with the wrong gearing then your fuel consumption could be much more noticeable.
When I got into helis I didn't realise quite how quickly I'd go through fuel. You can't compare it to a fixed-wing model because you're basically always using your motor somewhere around where it makes useful power at a fairly fast RPM before it's geared down to the blades around the 1700 rpm mark - so as a guess your motor is always going to be running at around 15000+ rpm. So, there is not getting away from the fact that you're converting a load of dead dinosaurs into smoke and noise at a pretty fast rate. ;-)
My first IC heli was a Fury 60 Expert with a YS61ST2, and it's a thirsty little motor but boy is it powerful. Imagine my horror when I also bought a Fury 90 Extreme with a YS91ST4 and discovered what a really thirsty beast that is. Wow. Wouldn't trade either of them in though as they are both simply awesome machines with stunning performance.
Phil
Phil
With lower nitro you will use LESS fuel.
So trying 10 or 15% might help you out.
Of course you will have a little less power (also probably 10 to 15%)
And you save *A LOT* of money as nitro is 10* as expensive as methanol
The main reasons to use nitro are (1) a little more pwer (2) a little more cooling
In all, a bigger block running less nitro is WAAY more money efficient than a small block on high nitro.
Only if you want the ultimate power/weight you go for 30% and higher
