RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Perry pump problem
Old 11-09-2002 | 05:29 PM
Default Perry pump problem
Ok guys, I installed a perry pump on my heli about 3 weeks ago and I used the hard red tubing from the pump to the crankcase as the instructions strongly recommended that you should. Here's my problem... the tubing keeps breaking right at the pump and keeps shutting the engine off . Although i'm getting quite good at autos now, i'd rather land when i want to. Anyone else had this problem?? Is another type of tubing acceptable?
Old 11-09-2002 | 08:51 PM
My Feedback: (8)
I had the same problem, the engine vibration is what causes it. What I did was just put the pink stuff (Prather's Fuel Line) on it. It's a lot softer but it seems to be working very well. What size engine do you have this on?
Old 11-09-2002 | 11:59 PM
OS 61 SX-H - i tried some of that pink tube and i cant tell a difference from the hard red one. I went through about 1/3 gallon today and no problems at all. Guess it's not such a big deal what you use. Only thing i had to do was use some light glue for the nipple to keep the tubing on. It had a decent fit but the pump has no flange to keep it on tight. I was afraid it might blow off during flight.
