gyro/linkage question
Ok I have a raptor 30v2 with a g500t and 810g servo. The manual for the gyro states that the linkage should be 15mm from the center of the servo...ok no problem...but I have to set the gyro to 40%-45% gain for it to not hunt. The gyro states to move the linkage ball one hole in toward the center until I can get gain value of 90 on low rate and 75 on high rate.
I have not tested because it has been snowing here but my concern was the linkage is now about 8mm from the center.(it was only like 12 to begin with, 15 was just crazy) OH! the manual for the raptor states it should be 10.5mm I beleive...
I'm so confused...
Also should the gyro be set to high rate with the 810g servo?
Thanks in advance.
I'm so confused...
Thanks in advance.
