RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Hirobo Sceadu Evo
Old 02-16-2006 | 11:45 PM
Default Hirobo Sceadu Evo
Hey There
I am just completing construction on a Sceadu Evo and was wondering if anyone out there knows wether the tail blade grips on the Evo are supposed to feel 'loose' in relation to the bearing and thrust bearing. They appear to move in and out as well as side to side, and this seems a bit strange. The thrust bearing is around the right way according to the manual, but my gut tells me it should be the other way round, ie the smaller inner diameter closest to the tail housing, this would seem to prevent the 'looseness'
Any ideas would be much appreciated
Mike
Old 02-17-2006 | 12:41 AM
MAX NITRO's Avatar
Default RE: Hirobo Sceadu Evo
Hi Mike,
Yes they are supposed to have that feel, they tighten when centrifugal force acts on them when they spin-up. I'ts just the way they designed it
Old 02-17-2006 | 01:20 AM
Choice, sounds good to me.
Thanks for the help
Mike
Old 02-17-2006 | 10:09 AM
sceadu37's Avatar
mine are like this...
one has a sold feel, and one is quite sloppy side to side...
have i put the thrust bearings wrong one one of them?
Old 02-17-2006 | 10:24 AM
Flyfalcons's Avatar
Wouldn't hurt to take the grips apart and check the bearings. You can see which part of the bearing has the larger inner diameter by sliding it on the hub and moving it side to side. The part with the smaller inner diameter won't move, but the one with the larger inner diameter will.
Old 02-17-2006 | 11:33 AM
sceadu37's Avatar
one of them is assembled the wrong way...
will this hurt??
i cant get the bearing off to change the thrust races round [&o]
Old 02-17-2006 | 10:10 PM
Ken Bryant's Avatar
My Feedback: (10)
Find a way and get it fixed. If it costs you a new tail hub it's still far better for it. FWIW, the hub is only around 5 quid at the most.
