Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Freya Tail Blade Holder Assembly Question >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 12-04-2002 | 07:55 PM
Isaac F's Avatar
Default Freya Tail Blade Holder Assembly Question
Hello Jeff, I am assembling the Tail Blade Holder´s of my GPH 50. They are the same of the Freya, with 3 bearings.
When I have every thing instaled in the slots of the blade holders the trust bearing has some longitudinal play. Ist this is ok?
I has not put grease yet. When I close the blade holder with the four screw, if I moved near my ear, I hear they are dancing
I check every thing is installed the way the manual says.
I have put in the tail housing first the big sealed bearing then the large diameter part of the trust bearing Then the balls carrier, then the small diameter one follow a small washer and the a open bearing.
THX
Isaac
Old 12-05-2002 | 06:09 PM
Yes Isaac that is ok. Some longitudinal play is normal.
jeff G
Old 12-05-2002 | 06:27 PM
Isaac F's Avatar
Ok, thank you........................know what grease you recomend me to use in the trust bearings???
Please give me various brands or types.
I have to luck if I can get it here in Panama
THX
Isaac
Old 12-05-2002 | 06:47 PM
Isaac F's Avatar
THX
Isaac
Old 12-05-2002 | 07:17 PM
Use a silicone based grease. The stuff I use is generic. Tamiya makes some good stuff in modeling size.
jeff G
Old 02-27-2003 | 08:21 PM
Default New machineˇˇˇˇ
Congratulations. Please let me know when is going to be its first flight. I would like to see that baby machine. By the way, you can find silicone based products at Centro Industrial tel. 224-2233
Carlos B.
