RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Vario Kit
Old 12-07-2002 | 02:03 AM
Default Vario Kit
Joe i am trying to put the front retract together on my Airwolf kit & i asked Vario UK how the pushrod attaches to the balls on the arms. I was then told i should have the plastic clips & pushrod for the retract in the kit. I dont have such items. Is the pushrod & the plastic clips suppose to be in the Airwolf kit? If so im missing them. Is there part numbers for these parts ? as the instructions do not show these items.
Many Thanks
Old 12-26-2002 | 04:58 AM
Default AirWolf Linkage
Staticx, I have built and flown about 8 Carbon Airwolfs. The Nose Retracts are best if you use a Ball Link and Rod from your retract servo. Should be pretty straight forward After you mount the servo. Make sure things line-up and you have your endPoints adjusted properly. Good Luck on your Project!!
Dr.Tim (VARIO REP.)
