things to take in mind!
hi everybody
i am soon to by my first helicopter and i need some pointers of what to do and not to do!
just some basic tips whold be wery good foor a noob
DO use a simulator
Do find someone who knows how to fly heli and can make sure setup is right.
DO use a radio that others around you use for heli's
Do expect to crash.
DO start with something like a Raptor- cheap and easy to get parts and everyone knows how to work on them.
DO use a simulator (it will save you thousands)
DO not try to land of loose carpet, cardboard, etc.
DO not spool up on a hard surface.
DO not let your engine run too lean.
Do not forget helicopters attract bystanders like flys and be aware you might need to avoid a fool.
Do expect to crash.
ORIGINAL: mantis*tw*
why?
why?
I wouldn't say its too big of a deal though, just a little spin (like half a turn maybe; depends on how fast it spools up)...
No, don't spool on a hard surface because of ground resonance which can destroy a helicopter.
Ya, I almost found the new "no parking" sign post on the street last week, was right in the southern approach to the oil derrick (simulated). Would have been a mess.
ON, CANADA
ORIGINAL: Helijack
Ground resonance will happen regardless of the surface you're on as far as my understanding of it goes. Although, it's not a common problem with RC helicopters, and only usually exhibits it's self if your landing gear or mechanics are poorly maintained, or you just got a poorly molded helicopter.
Looking for a more scienific answer for another post, i checked Wikipedia about Helicopters. I found this interesting:
Note that two bladed helicopters are not susceptible to ground resonance because they do not require lag-lead hinges. Two-bladed rotors remain balanced through all flight conditions.
But! Would our helis be two bladed, or do the paddles count for this as well, making them basically four bladed.
