Venture Tail Problems
Have a venture, 401 gyro, jr 8411 digital servo for tail.
Flies fine then all of a sudden will turn a hard 90, or just start spinning as if you lost tailrotor. Then stops & flies fine again.
A friend of mine has the same set up, & his does the same thing.
Comments.
Thanks -
Comments.
Thanks -
UT
A freind had the same problem, I backed the gain way down to about 25 and the problem diappeared. I have talked to a few people about it who had similar problems with the same gyro and servo and it seems that they had to back the gain way down also.
