Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Initial needle settings for OS .32 SX? >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 02-03-2002 | 08:08 PM
Default Initial needle settings for OS .32 SX?
Hey gang,
After too much futzing with the Thunder Tiger .36, I am going to replace it with an OS .32 SX and Weston pipe. What kind of needle settings are you using with 15% Cool Power fuel?
Tim
Old 02-03-2002 | 08:50 PM
Start with 1 1/2 on the main, 2 1/2 is way to rich. You'll end up with the mixture screw too lean to compensate if you start there. Leave the mixture screw where it was set at the factory. If you have changed it I have had good luck with setting mine at 2 1/2 to 3 turns out to start. Be sure the throttle is fully closed when closing the mixture screw before adjusting it.
Old 02-03-2002 | 10:55 PM
I thought that was probably what you meant.
