RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
CCPM angle change
Old 01-12-2003 | 02:53 PM
Default CCPM angle change
I have a Caliber 30 setup for CCPM (or EMS as Kyosho calls it). I have noticed that as I increase the throttle and collective pitch, the swash plate angles slightly to the right. Is this normal ? I'm not sure if this is by design and meant to counteract some tendancy for helis to pull to the left during high throttle/pitch moves, or if I may have some slight difference from one servo to the next. I am using and RD6000 with 94322 servos and 120 degree CCPM. I have flown the heli six times now. It seems a little hard to control, but since I am new to helis I don't have much to compare it to. This is probably normal, and just shows how difficult helis are to fly. Should the swash plate angle change slightly as I increasethe collective pitch ?
Old 01-12-2003 | 04:12 PM
My Feedback: (68)
Default ccpm help
No. You have some sort of cyclic to pitch interaction. Ideally, the swashplate should remain level during any collective pitch changes, and you should not have any collective pitch changes during a cyclic move. This interaction can be from mismatched servos, incorrect linkage length or setup, sticky links, or a programming problem.
