Average Glow plug life in a 60heli
ON, CANADA
Hi, I keep a flight log for my helicopter & just needed some info on the average life span of a OS #8 on a OS61LX-H engine.
It helps to know as to when to think about replacing it!
preventitive maintenance log basically with things like ave gyro tape life, tail gears, clunk line, clutch liner, maingear life, glow plug extension, 401 gyro life ETC..
How many of you keep a accurate log of your flights, flight hours anyway??
RE: Average Glow plug life in a 60heli
No answer for your question, but I keep a log as well. The good thing about the log is I can always revert back to the settings that work if I begin to play with the settings of the Heli. It makes adjustments easier not having to remember the previous setting.
NY
A plug can last a season all things being perfect and tuned right. I will change a plug when the engine starts to run poorly and can't be tuned to run better. Also keep in mind that if you run out of fuel in mid flight and the engine dies from lack of fuel at a high RPM that too can shorten plug life. But generally speaking the plug can last all season long.
