I Can't set the Mixture on my tt36
TN
Are you running dedicated heli fuel or just the airplane stuff? You should be running fuel with at least 20% full synthetic oil. Thats what I run in my TT 36, and it runs great. A heli should smoke alot. On the TT, you know if your engine is getting to hot by how hot the backplate is. The OS 32 should run cool enough that you can touch the backplate without getting burned, but the TT should me a little hotter. On mine, I've found that with the engine set perfectly you can touch the backplate for about 3 seconds before it gets too hot. Also, are you sure its overheating and not running so rich that its bogging down and quitting?
