Help! Problems with OS 32f in Raptor
I purchased a second Raptor as a back up heli that has an OS 32f
engine. I have put a new piston,sleeve & bearings in engine & still cannot get it to run right. The engine runs great for about a minute (puts out good smoke) & then seems to lean out & power begins to fall. (I assume the engine must get too hot) . I tried both 15% &
30 % fuel,new glow plug, & everything else I can think of.
Any suggestions other than replacing with the OS 32sx. I have read where others have used the OS 32f with no problems. I would sure like to have back the money I have spent on this to put toward the OS 32 sx.
Are you sure the problem is in the engine? Take it out and run it on the bench with a seperate fuel system, and see if it does the same thing. I sound like it may be loosing pressure in the tank, but this is only a guess.
Thanks for the info. I should have given a little more info on the engine settings. My low end setting is about 1 & 1/2 turns out from full closure & my high end is about the same. The engine will run great for about 1 minute at half stick before it cuts back & starts loosing power. All the fuel lines have been replaced.
I am going to try leaning the low end & richen up the high end. The engine is very rich at low end now.
Thanks again.
Thanks again.
