Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 Fishtailing - please help! >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 09-23-2007 | 08:51 AM
Roger Suckling's Avatar
Default Fishtailing - please help!
Hi,
I have a Sceadu Evo 50 that has been laid up for a while and since I have dusted it off it has a problem I don't recall it having before.
All is OK at moderate head speed but as soon as i clip up the revs with the first stunt curve it fishtails continuously. If I back off the gyro (CSM SL560) gain it helps but the tail feels less locked. I have checked all the boom stays etc are tight, tail servo is a JR8700, belt is ok, no apparent vibration, i even tried a smaller horn on the rudder servo but no better. I have a throttle Jockey on it so I can change the revs a little at a time and it doesn't take much of an increase to set it off.
Any Ideas?
Thanks in advance
Roger
Old 09-23-2007 | 09:30 AM
Default RE: Fishtailing - please help!
HI THERE HELI FRIEND,THE PROBLEM MAY BE LOST MEMORY,I HAD THE SAME WITH MY 401 GYRO,YOU HAVE TO REINSTALL THE GYRO,AN GO THROUGH THE SETTINGS AGAIN,I NOW THIS IS A PAIN BUT IT WORKED FOR ME,IF IT DOES NOT WORK THE YOU GYRO HAS GOT DAMP IN IT ,OVER A LONG STORE,HOPE THIS HELPS,REGARDS HELINELLY NEIL
