Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 HELP!!!!  Walkera problem >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 12-14-2007 | 10:37 PM
Default HELP!!!! Walkera problem
I am kind of new to the r/c heli hobby (about a month) but I have worked in the aviation maintenance industry for several years and have a fairly good understanding of flight. But what has been frustrating is my r/c heli has a very steady left drift or right that I can not overcome with trim settings. It also has a prety steady left or right rudder drift that, when trimmed either left or right, does not correct the issue. It has been about as impossible as anything I have ever done to get this thing off of the ground. At one point, I gave it substantial throttle and got it up about 15 feet in the air and it was all over the place (and quite uncontrollable I might add). I had to kill the throttle and crash land in the neighbor's bushes (it was that or else it was going through the second story bedroom window).
Simply put, I need some pointers on what to do. I have made adjustments to the trims with no avail as well as giving stick control when attempting take-off. It goes from one extreme to the other. Any advice from the more experienced crowd?
Old 12-14-2007 | 11:01 PM
Default RE: HELP!!!! Walkera problem
don't take this the wrong way but I think you're probably just giving too much input on the sticks. the heli will want to drift left on take off. you need to get up to about 6 feet in height to stop these problems.
the main thing is that you need to input constant small commands, trying to hover the heli is like trying to keep a ball bearing in the middle of a glass plate, if it starts to roll one way you don't do and extreme tilt to get it back to the middle, you do a very small movement.
go through radd's school of rotory flight and get a sim to practice on (they may be expensive but you'll spend the same amount on broken parts).
Old 12-15-2007 | 11:24 AM
HeliTB's Avatar
If you have computer radio or if you get one. You can set some EXPO to remove some of that sensitivity unitl you get better.
