Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 blades spin intermitantly >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 12-29-2007 | 08:42 AM
Default blades spin intermitantly
just had my first crash, heli was only 2 feet off the floor so it didnt come down too hard.
problem now is thst when i start to give it throttle its startes ok but as it starts to get fasterthe power stop and starts for a couple of times and then wont spin at all. if i turn it all off and back on again it does the same thing everytime. is it possible that this is a fault in the esc or the receiver?
Old 12-29-2007 | 09:40 AM
rcjet lynch's Avatar
Default RE: blades spin intermitantly
Mark wich heli do you have?
Old 12-29-2007 | 10:51 AM
jaketrouble's Avatar
i just encountered the same problem with mine.. my main gear was missing some teeth and thought it was that... i was wrong.. turned out to be the esc... my baldes would spin up real good and then they would slowy stop.. tried everything... then i swaped out the esc with one of my other birds and sure enough it was the esc..
its only had a few flights on it but my last crash a main blade stuck in the ground.. i think the baldes strike is what stripped my gear and caused the esc to short out because of the sudden stop on the blades???? jake
Old 12-29-2007 | 03:16 PM
Thanks Jake
For some reason after charging the battery up it now works ok!? I dont know if this is normal for when the battery starts to run out (although it didnt seem to be low) Guess it just fixed itself
Old 12-29-2007 | 03:17 PM
My heli is a Raptor G2
