Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Deflector does reduce power >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 04-14-2003 | 06:43 PM
Default Deflector does reduce power
Your local hobby shop is right . . . A deflector will in fact reduce your power.
The reason your heli had less power AFTER you removed your deflector is because the high mixture needle needed to be re-set.
Old 04-14-2003 | 07:36 PM
Charlie's Avatar
The reason your heli had less power when you removed your deflector
So does it have more power with or with out it?
Old 04-14-2003 | 08:06 PM
Default Correction
Sorry for the confusion, I adjusted my statement above.
Old 04-14-2003 | 09:02 PM
Galifrey's Avatar
so if your engine has plenty of power with a deflector... do you need to remove it?
I put a 90 size on my 50 and its fine... still only using 85% throttle on a climb out or it massively overspeeds... with +10 on the top!
Beauty is the model stays a lot cleaner...
Old 04-14-2003 | 09:26 PM
Default Deflectors
I have a Raptor v1 30 with a Westin Tuned Pipe. I initially put an exhaust deflector on my raptor to minimize the cleanup as much as possible.
After putting the deflector on, the mixture was off and after re-setting the mixture, there was a loss of power. (not much, but when you are flyiing a 30, it is enough of a change to make you think twice about the hassle of cleanup)
The deflector was extremely close to the ground (within 1/2") and so I decided to remove it. The nice thing about my Westin Pipe is that the exhaust port points down towards the ground minimizing cleanup.
If you are running a 60, or 90, then power should not be an issue.
Old 04-16-2003 | 09:24 PM
Galifrey's Avatar
if you add a defelctor to a tuned pipe then you are gonna slightly affect the tuned length, but not by a massive amount, yes it will reduce power slightly (otherwise weston would have made the outlet longer) but try using an outlet that is much larger, ie designed for a 60-90 and then the effect is much less...
