Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 HELP WITH os max 46 fx heliengine setup >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 01-26-2008 | 04:24 PM
Default HELP WITH os max 46 fx heliengine setup
HI THERE GUYS CAN ANY ONE GIVE ME THE BEST SETUP TUNE FOR MY OS46 FX HELIENGINE.ITS RUNNING LIKE A BAG OF SPANNERS AT THE MOMENT.PLEASE HELP REGARDS HELINELLY NEIL
Old 01-26-2008 | 05:30 PM
Default RE: HELP WITH os max 46 fx heliengine setup
Hi Neil,
I'm not expert whasoever, but I have a friend that has that same engine and he is having a lot of trouble tunning it.
I read on different forums to try to help him and found out that apparently is a very well known problem the tunning of this engine.
There is a modification for the carb if you look around you might find it I tried but I don't seemto be able to open the right page
You can read here http://www.runryder.com/helicopter/t...ight=os+46+mod
I hope that helps,
On another subject, typing all in Caps is considered shouting (just so you know)
Fernando
Old 01-26-2008 | 10:06 PM
RTFM
Old 01-26-2008 | 10:30 PM
evan-RCU's Avatar
The early one's had a rich mid range when the top and bottom were adjusted correctly. First you need to get the top and bottom adjusted right and then see about the transition through mid throttle. We need a better description than it's running like a bag of spanners....
Basic adjustment is the open the high speed needle about one and three quarters turns and start and hover it. Will it hover? what it the head temp after hovering? Should be 200-220deg F. Is there smoke? What fuel?if it hovers and the temp is good but the idle is off start the motor and get it idling. Hold the head so the blades don'e turn. Pinch the fuel line. It should run normal for 5 seconds before reving and then dieing. Try all this and post what you have...
Old 01-27-2008 | 05:33 AM
thanks for the help guys.i will give it ago a let you all no.kind regards helinelly neil
Old 01-27-2008 | 08:18 AM
BarracudaHockey's Avatar
If "bad of spanners" is a description of the noise its making then you probably need bearings. If thats just English humor for running crappy, well as Evan said, that thing has some known carb issues.
Old 01-27-2008 | 09:50 AM
evan-RCU's Avatar
The early one's had the problem. The fix was to file a "V" in the carb barrel. You need to find out first if your's is running bad just because of poor adjustment before breaking out the grinding wheels and implements of destruction.
I remember there where certain carb numbers involved but I don't remember exactly which one(s).
Old 01-27-2008 | 11:05 AM
the mid needle is three turns out an the main needle is two turns out,it seems to be flying great.thanks fellows i new someone would no how to set it it beautifully.sorry guys the term bag of spanners refers to running out of tune.regards helinelly
