Idle Up 'stuck' on Hi Tech Eclipse 7
The 'idle on' warning seems to be stuck, on my Hitch Eclipse 7 radio. I have switched the Flt. mode switch back, but it makes no difference. Whatever model setting I use, it comes on, so long as the model is set to 'heli' mode!
Can someone PLEASE tell me how to reset it - I was meant to be flying today!
Steve P
Steve P
try this
I too have an eclipse. I have the (on top) left, front button set so that all the way to the back (towards the trainer switch) is my 'normal' flight mode. If it is in any other position I got that error message. It doesnt seem to have anything to do with the idle up switch on the left.
Hope that helps.
Hope that helps.
hello i to had the same problem, which needed a new chip inserted into the tranny.i had in total 5 big problems with my hitec 7 .needless to say i have it no more.if you get it fixed sell it and get a ff9 loads better.
Same Problem?
Thanks for the message AJM. Odd, because Mike Mayberry, at HiTech assures me that he's never come across a problem like mine before
Steve P.
Steve P.
hello .problem 1 .pitch fault new part .
2 . idle stuck on .new chip.
3 .throttle fault .new chip.
4,5 big smashes due to another prob but got a ff9 so did not use any more.
yes it certainly happened to mine
carry on crashing
ajm
carry on crashing
ajm
