Reducing Pitch
BC, CANADA
I just rebuilt my T-Rex after a pretty bad crash and I'm finding that with 0 pitch at center stick, I'm getting +12 and and -12 at high and low stick. I've seen instructions for increasing pitch, but none for reducing the amount of pitch. I'm using a DX-6. Any ideas which links I should be adjusting, or is there something I need to do in radio programming to change it.
AB, CANADA
no, under swash AFR you'll find settings like
Pit +60
ELE +60
Ail -60
What ever the value is for pitch reduce it. Don't worry about the sign in front, I think stock is 60 so change it to 50 and see what that gives you.
Pit +60
ELE +60
Ail -60
