RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
electronics swaping??
Old 04-28-2008 | 10:29 PM
My Feedback: (16)
Default electronics swaping??
I used my HBK2 electronics on my Compy FP. My question is that my Compy is a FP and my HBK2 is a CP. When I use the stock electronics from the HBK2 on the Compy the channel 3 throttle/speed controller does not activate the throttle it just raises the servos up or down on the swashplate. Any way I can change this? Also how do I set-up a new telebee head lock gyro if my heli constantly spins right??
Old 04-29-2008 | 06:31 AM
Default RE: electronics swaping??
I don think you can use the HB2K electronics if the other heli has a tail motor (?) without extensive mods using another speed control for the tail. Does your heli have a tail motor?
Old 04-29-2008 | 11:27 AM
My Feedback: (16)
The compy 300 is a fp but it uses a beltdrive. I have a brushless set-up on it. I was wondering if there was a way I can make the transmitter 4 channels instead of 6?
Old 04-29-2008 | 12:09 PM
Are you using the HBK II tx? I heard that to use a HBK II Rx you need to use a 4ch Tx with it, I'm gonna try in a little bit, I have all the parts laying around, I was gonna use the set-up for my SuperFP so guess I'll find out now if it works
Old 04-29-2008 | 02:40 PM
My Feedback: (16)
Yeah I figured it out. I have the HBK2 Rx with a HBFP Tx setup that works fine. Whats the best way to setup a new gyro? I have a telebee on now that goes into super right spin mode instantly???
Old 04-29-2008 | 03:21 PM
try reversing your gyro direction. Sounds like it's reversed.
