Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Do you wear a neck strap? >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 05-16-2003 | 09:33 PM
Default Do you wear a neck strap?
I was just curious about how many of you guys wear a neck strap on your Tx. I personally wear one, because It helps me to stay consistent with my techique. I have the strap adjusted to allow my arms to extend to a comfortable position, and they stay in the same position each time I fly. I even use it with my simulator, so when learning something new, it will have the exact same feel, with my heli. During the training stages, I was nervous and was choking up with my arms, without realizing it, but as soon as I noticed what I was doing, I extended my arms to stretch out my neck strap, and I imediately began to improve, because my techique was the same as what I learned on the sim.
Mike
Old 05-16-2003 | 10:20 PM
Apart from the fact that it helps you get a better feel on the sticks, I think one of the main reasons why people use a strap is to support it so you don't need to hold it the whole time whilst flying. You could get a bit tired and when you go and flip throttle hold or an idle up you drop the thing. I've seen it happen, definitely not a pretty sight! It leaves you with about 2 second to pick it up, find your model, re-orientate yourself and correct.
Anyone who doesn't use one, I would like to hear why. It's ok having co-pilots, fail-safes, training gear and whatever else, but it what about protecting the main control system.
James
PS: One disadvantage is for fixed-wing pilots who I have seen keep their Tx's strapped on while they are starting they're engine, and then their 12x6 chops through their 3810 or 9c. Seen that happen too!
Old 05-17-2003 | 04:20 AM
WhtBronco's Avatar
I wear with helis but not when flying planes. I find it hard to get on while holding the planes. I also do not flip switches on/off as much with planes.
Old 05-17-2003 | 03:39 PM
My Feedback: (9)
I do all the time,both on the sim and with planes and helis. I flew in a pylon race a couple weeks ago. I was the only one who had any kind of tx support and most were flying with only thumbs.
basmntdweller
Old 05-17-2003 | 03:44 PM
You're kidding!! You'd think more guys would opt for Tx support.
Not only do I use the strap, but I also use a modified version of the pinch techique.( Thumb on top, index finger in front) My control is much better this way.
Mike
Old 05-18-2003 | 12:35 PM
Galifrey's Avatar
Ditto your pinch technique mike...
I also do it that way....
Old 05-19-2003 | 03:02 PM
FLYBOY's Avatar
I am the same way. I use a neckstrap too. Makes it smoother.
Old 05-20-2003 | 09:36 PM
I'm new to helis and have transferred the 'pinch' from my pattern & 3D fixed wing days....I never considered the neckstrap, but based on the commentary, I think I'll give it a shot at smoothing things out a bit....ThanX
Old 05-20-2003 | 10:46 PM
Give it a try tdbone. I believe it will help you stay consistent. It sure has helped me. BTW, the Atlanta Braves are kickin' A** this year aren't they? I'm a big Braves fan.
Happy flying, Mike
Old 05-21-2003 | 05:03 AM
My Feedback: (45)
Hi, i never used the neck strap because i just learn with out one and i got used to not using one, i try it once but i did not got used to it but i will give it another shot to see if i feel the diference thanks
