RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Servo question
Old 08-23-2008 | 10:03 PM
Default Servo question
Will a Spectrum Servo work on a Thunder Tiger Raptor? Cause i have 4 spectrum servos and 1 hobbico command servo, will these work together?
Old 08-24-2008 | 01:44 AM
Default RE: Servo question
Depends on what servos and what raptor. The spektrum DS821 servos that come with the DX7 radio set are not recommended for .50 size nitros or larger. So as long as it's an electric or a .30 raptor you should be fine. As long as all the cyclic servos are the same you can use the hobbico and 4th spektrum servo anywhere (I'm assuming you're thinking throttle and rudder), put the faster servo on rudder.
