RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
DELETE
Old 03-16-2002 | 05:07 PM
Default DELETE
Thanks to the people that helped me out!
Old 03-16-2002 | 08:37 PM
Default DELETE
even for a beginner i would recommend to hover (+4/5) at 3/4 stick. that makes center stick 0 full positive at 10 and limit your negative through to -4.
throttle should be at high idle at low stick (-4) about 35-40% at center (0) about 50% at hover (+4/5) and 100% at full stick.
i believe that is a pretty save setup for starting.
do not learn hovering at center stick, it is a bad "habbit"
of course like always that is my opinion and there is tons of other ways to do it.
what heli and engine do you have?
Old 03-16-2002 | 09:54 PM
Default DELETE
Raptor 30, o.s. .32. BUt the linkage is screwed in all the way, how am i suppose to get it to 5 or 6? Is it because something else might be off. I know that the servo the controls the up and down, is in the 2nd spot, not 1st if you know what i mean... LMK
Old 03-17-2002 | 10:28 PM
Default DELETE
i do not have a raptor so it will be hard for me to tell offhand which linkages might be off, but do a search for raptor help on website and you will find tons of it, i am sure some with pics showing the correct setup.
or some one else here might be able to help
Old 03-17-2002 | 10:40 PM
Default DELETE
Got it fixed! Thanks for your help..
