RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
engine overheating
Old 11-15-2008 | 05:36 AM
Ragz's Avatar
Default engine overheating
I have a sceadu 30 with a os 37 engine in it. The engine has had about 15 flights on it. The last few days I have noticed that its overheating and the smoke quantity has reduced a lot as well....so I richened it on the high speed needle. There is no real effect on the performance. Even with 6 turns out, the engine is overheating, and bogging down like crazy. The low speed needle seems fine, as the transition is really good. However, I have richened that considerably as well...went up to 1-2 turns. Seems like the needles are not making a difference to the mixture. The engine is smoking hot when I shut it down. What could be happening? I am using 20% nitro fuel with 20% oil.
thanks in advance
Old 11-15-2008 | 07:35 AM
chris6414's Avatar
My Feedback: (10)
Default RE: engine overheating
Check all engine screws and glow plug for tightness. Fuel restriction or air leak in plumbing or motor
Old 11-15-2008 | 09:34 AM
ORIGINAL: chris6414
Yep I agree Chris, I bet the plumbing is leaking and or the muffler pressure nipple is stopped up or the carb is not set tightly down on the O ring. Ya got air matey!!!
Jim
Old 11-15-2008 | 07:08 PM
also make sure you do not have the needles set to lean.
