Is more blades better?
BC, CANADA
Is a heli more stable with more blades on one plane? Like you see from two right up to five blades on one rotor. Is this more stable and is it easier to fly with more blades
AB, CANADA
RE: Is more blades better?
most helis with more than 2 blades are designed for scale flying flybarless. almost all 450 size and larger have 2 blades and a flybar.
if you go 2 blades flybarless then you have more agility, when you go more then mostly it's for the scale look.
