copterx setting to dx6i
What setting do you need? Every chopper is a bit different on setup, even those just like it. The motor type and blades will need to be fine tuned. What servos are you using and typr of gyro and tail servo?.
To get you started you must set your pitch curve for the middle 3 point to 50% tempoary. Then adjust the pitch to 0 with the stick centered. You will need to adjust linkages and so forth. Once that is set change the values in the pitch curve to have -3 +5 +10. In thecurve you will notce a little line. .Set the 1/4 and 3/4 point to where The lines will make a straight line between point 1-3-4. In Idle up you will want -10 0 +10. Your 3/4/point show match the 3/4 point for normal mode so when tou switch to idle up the heli won't jump. Yor throttle would be
0- 48-85-95-100. The 48 is a few points added so the heli wont slam down while landing and makes the heli easier to hover. In idle up your throttle would be 100-95-90-95-100.
Jim
Jim
