Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
different gas and needle settings >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 06-05-2003 | 12:11 AM
Default different gas and needle settings
I ran one gallon of regular gas at 75:1 then I switched to camper fuel at 63:1 the needles did not need to be changed,I switched again(experimenting different fuels) to what the manual calls for which is 95 octane or higher.I chose 94 at 82:1
When I started the engine the low speed was real rich.I had to lean it and at the same time the high speed was to lean I had to richen that.Does this sound normal or should I be looking at something else.
I'm a gasser newbie
Old 06-24-2003 | 01:51 AM
Default gas & needle settings
This guy is good! He goes by Billme on runryder. But here is a link to some of his setup tips http://www.ronlund.com/bmeador_gas.htm
Hope this helps. Works for me.
Todd
Old 06-24-2003 | 04:04 AM
Thanks for the link,but Billme and others already responded on RR in the gasser forum.
