xp783
hey i have a xp783 i know that this is capable of ccpm if turned on,so how can you check it to see if its on? i found this section of programming that says mix swas the setting are norm,3srv,and 2srv?does this mean that the ccpm is on?please if you have any info i would appriciate it.the man. does not go into that for some reason.thanks don russell.
I think you have it right. The 3 servo would be 120 Deg.
Try setting up a receiver and three servos, One in Ele,one in ali,One in AUX1. Move the throttle stick and see if all three move together.
hey rod i guess i just needed to call ya!!im going to try it.it was raining here all day so i was messing with the radio and it finally poped up.there is a whole lot more with this radio than the 662 kinda makes it look like a toy now if i can harness its power!ha.thanks don
